Replacing Shower Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-31-2011, 09:27 PM   #16
Rewards Points: 111
Thanks eplumber. I'm gonna try to drain out the pipes this coming weekend to put in the copper x pex fitting. I'll also add the copper piping to the sprout.
No one replied about the teflon threaded tape used to connect the pex joints to the valve. Should I use a pipe sealant here?
suncowiam is offline   Reply With Quote
Old 05-31-2011, 09:47 PM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 818
I was taught to use pipe dope and tape. And all the journeyman I work with use both. But if you have water tested your valve it and doesn't leak then I'd leave it alone. A lot of people seem to use only tape.
When trying to solder the adapters on, open a faucet to help drain the water. It might be enough to keep the water out of your risers.
Also make sure your valve is set to the right depth and secured well in the wall before you install the wallboard.
Old 05-31-2011, 10:49 PM   #18
Those connections on the shower valve look like a union or compression fitting, if so then you should not use teflon or past on the joint.
You should install an access panel on the other side of the wall so you have access to the valve and fittings in the future.
NickFixit is offline   Reply With Quote
Old 05-31-2011, 11:49 PM   #19
Rewards Points: 111
Nick,
I believe you're referring to the PEX clamps. Why do you suggest not using teflon in this case and I'm not sure what you mean by "past on the point."
The other side of the wall is the main wall of my bedroom. Our TV is actually there. If anything, I'll have to cut in the drywall in the future for this access.
New shower valve, no hot water? Chris112 Plumbing 0 03-19-2011 06:21 PM
Delta scald guard shower valve leak pdamania Plumbing 1 03-08-2011 05:45 PM
Can't Identify Shower and Tub rough in valve stamped SHWR 7196 and TUB P-P USA help4diy Plumbing 1 11-21-2010 09:06 AM
Shower valve installation sydni2009 Plumbing 3 09-21-2010 05:04 PM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 08:19 AM
