Replacing Shower Spigot - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-11-2008, 12:17 AM   #1
Rewards Points: 199
Replacing shower spigot
In my house there are no shut off valves to the shower. I have a single handle shower control made by Delta. I would like to replace it with a newer one. Could I replace the shower control and etruscan trim with another single handle Delta set without shutting off the water?
Arlo is offline   Reply With Quote
Old 06-11-2008, 12:27 AM   #2
Registered User
Termite's Avatar
Nope. In order to change out a valve body or valve cartridge, you have to shut off the water supply. It just can't be done any other way.
The escutcheon could be changed without killing the water. You simply take off the handle and unscrew the old one.
Need help replacing shower cartridge MrAngles Plumbing 7 03-01-2009 01:38 PM
replacing brass shower fixtures; how hard? tarheelblue Plumbing 6 01-26-2008 08:18 PM
Replacing Shower Fixture RTBTK Plumbing 1 07-27-2007 05:35 PM
Replacing damaged shower wall tiles kevind Flooring 4 11-20-2006 12:18 PM
Replacing damaged shower wall tiles kevind Remodeling 3 11-15-2006 10:36 PM
