Replacing Shower Head And Faucet Puzzle, Moen To Kohler - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-06-2011, 09:40 AM   #1
Replacing shower head and faucet puzzle, moen to kohler
Good morning,
Doing several projects around the home and the wife purchased a new shower head and valve from kohler... I previously had a moen head and facet... I am doing a master bath remodel and the shower is the only thing left... I didnt close up the walls yet to address this issue first.
The moen handle was a simple turn one way for hot the other for cold... This kohler is the same style, nothing to fancy.
1. Does one have to replace the valve when replacing the shower facet handle? This doesn't make since to me.
2. attached are two photos of the included adapter which shows a "spiked" stem adapter from kohler, while the other photo shows my stem is flat on two sides from moen... Can i buy a converter of sorts?
Replacing shower head and faucet puzzle, moen to kohler-photo-1.jpg   Replacing shower head and faucet puzzle, moen to kohler-photo-2-1-.jpg
rjwrightohio is offline   Reply With Quote
Old 11-06-2011, 10:01 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 682
You have to buy the manufacturers product line for the handle. Shower heads interchange though
Old 11-06-2011, 10:09 AM   #3
I apologize i just saw i wrote shower head and valve... I meant to state showerhead and facet handle. With that said, is your statement still hold true? handles need manufacturer's valve? If so that really stinks..
Old 11-07-2011, 07:02 AM   #4
Plumb or Die!
Yep, it stinks. You might find another Moen handle your wife likes, though?
plumber666 is offline   Reply With Quote
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
shower mixing value capping off faucet quetion vote4Pedro Plumbing 1 06-28-2011 03:12 PM
My shower head leaks when tub faucet is running? Walter Sobchak Plumbing 4 05-24-2010 08:13 AM
Low Flow Problem at Shower Head steveo178 Plumbing 4 12-27-2009 12:59 PM
Does not fully go from faucet to shower desimonkey Plumbing 1 04-21-2009 02:59 PM
