Replacing Shower Fixture - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-09-2012, 09:15 PM   #1
Rewards Points: 31
Replacing shower fixture
Interested in replacing my old shower fixture in my main bath. Currently have a 1 handle, knob style, want to replace with two handle. Can I make the swap simply by buying the new fixture and replacing or do I need to alter the pipes at all?
jmorc2003 is offline   Reply With Quote
Old 12-09-2012, 09:49 PM   #2
Rewards Points: 14,312
#1 By doing that your going to reduce the avalible selection of faucets by at least 75%. (we just went though all this, just go in any box store and check out the selections avalible. Everyones switching over to single handle)
#2 What do you plan on doing with that huge hole left in the middle by removing the old fixture?
The plumbing should be close to the same.
Old 12-11-2012, 11:58 AM   #3
Rewards Points: 31
Thanks for the reply. I agree that there are more single handle faucets. My current single handle requires the water to be turned on full blast in order to get hot water. Are there any single handles that will allow me to get hot water without the faucet being fully open?
Old 12-11-2012, 06:20 PM   #4
Changing the faucet is not going to fix that issue most likly.
It's more to do with the size of the supply line, distance from the heater, lack of insulation on the pipes, temperture the heaters set at.
Old 12-11-2012, 06:47 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 924
Check Delta's thermostatic valves. They might be what you're after
Old 12-11-2012, 06:53 PM   #6
Rewards Points: 31
Sorry, I see where my post was unclear. It's the style of fixture that requires me to open the faucet fully, or nearly full to get hotter water. If there were a separate hot and cold knobs, then I could open each slightly, get a lighter stream of water that is still warm to hot.
Old 12-11-2012, 06:59 PM   #7
Plumber
Rewards Points: 924
So you want variable temp control with seperate volume control- see my previous post
Replacing a light fixture JELLY DONUT Electrical 4 01-20-2015 10:07 PM
Replacing a Light Fixture with many wires flan3084 Electrical 7 12-31-2010 11:37 AM
Replacing Whole Shower - No Access Panel BA Barraccus Plumbing 3 06-22-2010 01:03 PM
Replacing fixtures and CVPC in shower pinkertonpv Plumbing 1 07-30-2009 06:18 PM
Shower faucet replacement - PVC replacing steel? jdm1 Plumbing 2 11-29-2008 11:38 AM
