Replacing Shower Drain In Concrete Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2008, 08:23 AM   #1
Replacing shower drain in concrete floor
Hi, My shower pan replacement project was going along well until I removed the 4 bolts in the shower drain that is PVC. All the heads were rusted off. I tried an easy out but that failed to remove the bolts as well. I really don't want to bust up the concrete floor to replace the drain if I don't have to. I know this has had to happen to someone else, so please, any help would be greatly appreciated!
rjgypsy is offline   Reply With Quote
Old 11-30-2008, 04:31 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
There are little kits to fit a reversible drill that you can get for removing small broken off screws and bolts. (I purchased two off of the Internet and gave one to a friend. Work great. Try www.getgrabit.com )
However, you should be able to find one at a big box in the hardware drill bit section.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Different type of shower drain? canadaclub Plumbing 8 03-04-2011 10:08 AM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 05:04 PM
sewer backup and stench jayhill Plumbing 12 08-14-2008 12:06 AM
New shower with existing drain jamesdcarroll Remodeling 1 02-08-2008 03:13 PM
Anyone know if it is code for a utility room floor drain? tigerbalm2424 General DIY Discussions 3 10-17-2007 11:48 AM
