Old 06-21-2010, 10:15 AM   #1
Replacing shower drain all connectors, no pipe
Redoing a shower in a weekend home that was leaking. Drain pipe was cracked (??how'd that happen??). Tore into the floor and found the drain pipe to be one connector after another for several feet. Even past the vent. Any slick tricks to fix such? Want to cut in to system and replace the trap and leaking connection. But to get to enough pipe to cut and have room to glue a connector, have to rip up more floor to get to the area with enough pipe. Hoping to avoid. Any suggestions?
Thanks so much in advance for any hints or suggestions.
nkovach is offline   Reply With Quote
need assistance with shower drain newbiemike Plumbing 4 02-02-2010 10:34 AM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 12:59 PM
New tiled shower won't drain; mortar in drain. catitudes Plumbing 5 03-29-2009 02:08 PM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 06:46 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
