Old 11-07-2012, 04:48 PM   #1
Replacing Shower Arm
Hi Folks,
I am in the process of replacing a 30-year old shower arm. I had some trouble breaking the old one loose but some oil and a little time with a pipe wrench got it started. When I pulled it out, it looked like some of it had broken off inside the pipe in the wall. Fortunately, after a few minutes with some tweezers, I was able to get all loose pieces out. So far so good, I think.
Unfortunately, I ran into trouble when I tried to screw the new shower arm into the pipe inside the wall. I think I am getting the new arm aligned, but I cannot get the threads to bite. Obviously, it is impossible to get any visual confirmation since the pipe is inside the wall and behind some tile. Feeling around the threads with a finger suggests that everything is fine, with no obvious damage. This leads me to think that perhaps the just the start of the threads of pipe are bent or somehow constricted and preventing the shower arm threads from biting.
Does anyone have any experience with this? Or any thoughts of a way to get the threads working again, using a tool for instance?
Thanks.
manusharma is offline   Reply With Quote
Old 11-07-2012, 04:57 PM   #2
Super Moderator
A 1/2" threading die would be Ideal----However, I would use a threaded pipe nipple first--the tapered steel pipe will usually straighten out the dinged threads inside the wall---then the softer shower arm can be installed----good luck----
Ed911 (11-08-2012)
Old 11-10-2012, 11:51 AM   #3
Thanks Mike, that's a great idea. I gave the nipple a try, but no luck. The nipple threads wouldn't bite either. I am really puzzled on how this could be since I can't imagine that the old shower arm could have damaged the threads on the outer end of the elbow. I suppose I will try a die next...
Removing a shower replacing with sink HuskySkull Plumbing 0 01-17-2010 01:08 PM
Need help replacing shower cartridge MrAngles Plumbing 7 03-01-2009 02:38 PM
Replacing shower drain in concrete floor rjgypsy Plumbing 1 11-30-2008 04:31 AM
Replacing a fiberglass shower Proulx06 Remodeling 11 06-20-2008 05:50 PM
