Replacing A Shallow Well Jet Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-26-2013, 10:38 PM   #1
Rewards Points: 422
Replacing a shallow well jet pump
Is this a difficult job? We have a point well, and the pump sits on the basement floor. Our regular plumber say he cannot do the job, and his "pump guy" is out for a couple weeks. I assumed any plumber can do this, but he says no, it's too specialized.
A different plumber came out today, and said it would cost $1,200 plus materials for him to do it. Needless to say, I said no thanks. Are the Flotec pumps at Home Depot any good? Thanks.
Jim McC is offline   Reply With Quote
Old 08-26-2013, 10:54 PM   #2
Rewards Points: 940
Generally, when you change something out, you take out the old one and put in a new one.
cleveman is offline   Reply With Quote
Old 08-27-2013, 12:25 AM   #3
Rewards Points: 422
I'm sorry, but that doesn't help me or answer my questions.
Old 08-27-2013, 08:32 AM   #4
I changed mine, simple, just take old one out, re-hook your plumbing up, i replaced the expansion tank. prime pump several times, check and adjust pressures if necessary...
JimL is offline   Reply With Quote
Old 08-27-2013, 09:14 AM   #5
joed's Avatar
Rewards Points: 11,966
Pump should just plug in so no electrical required.
Pump should have two pipes, one from well and one to house.
Disconnect the pipes and connect to new pump. I can't say much more than that without actually seeing setup of old and new.
Prime pump and run.
Old 08-27-2013, 01:41 PM   #6
Rewards Points: 446
To install a new well pump in Wisconsin a professional (not the homeowner, and working for payment) must have a pump installers license. A homeowner can install their own as long as it is done to code.
Is it something that you should be able to accomplish by yourself? Only you can answer that. Look very carefully at what you have now. Take pictures and take them with you to wherever you plan on buying the pump. Hopefully someone there can look at what you have, discuss what needs to be done and between the two of you help you make a decision if it's something you feel comfortable doing.
If this is something you've never done before or you're not familiar with doing plumbing work plan on learning some of the finer print details of what needs to be done to install a shallow well pump and what can make it not work correctly. Check if the store has some kind of handyman's book or booklet on the process.
Biggest problems with installing this kind of pump is how it was installed in the first place in particular:
Do the new pump and old pump have the same size fittings and are they located in the same exact place?
What kind of piping was used on inlet and outlet?
Do you have the tools required to work both on the piping and possible electrical?
Make a list of items needed and buy EXTRA of each and if you'll need galvanized piping buy lots of extra short pipe lengths (nipples). Most every place will allow you to return for credit items not used and in sellable condition.
Like anything else, you don't know what you don't know until you have to know it.
old_squid is offline   Reply With Quote
Old 08-27-2013, 05:51 PM   #7
Rewards Points: 422
Thanks guys. What about the price I was given? Isn't $1,200(including pump) plus materials VERY high?
Are the Flotec pumps at Home Depot any good? If not, what do you suggest?
Replacing Split System Heat Pump singletoo HVAC 10 06-02-2013 07:56 AM
Replacing sump pump pipes Cossack Plumbing 12 05-23-2012 09:41 PM
MasterCraft shallow well pump not happy rtoni Plumbing 7 06-06-2011 12:41 PM
Replacing basement sink pump kornfein Plumbing 0 04-23-2010 01:56 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
