| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Checking Ball Valve Installation
by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you step 6 of installing a ball valve. I am going to go ahead and show you a few tips for soldering. I am going to solder this ball valve on the ground primarily for the... Read More »
How to Take Copper Pipes Apart
by eHow.com
Taking copper pipes apart may be necessary if you're remodeling an older home or if you have a leak between a pipe and a fitting. It's a job the home handyman can handle with the right tools. Just follow the steps below. Read More »
How to Apply Flux to Copper Pipes
by Expert Village
Hey everybody Don Golden with Expert Village and we're moving on with our copper piping. I'm going to show you now what you need to join these in everlasting matrimony. What we are going to do is we are going to use what is called flux paste. This is a... Read More »
How to Remove the Lip on a Copper Pipe
by Expert Village
Hey everybody Don Golden for Expert Village and we're back with copper piping and we've cleaned the inside and the outside of the pipe that we're going to be soldering today or sweating and if you're going to use this copper as a true water application... Read More »
How to Install Pipes Under the Kitchen Sink
by Expert Village
I’m Lee. I have a degree in architecture and about ten years construction experience, and today we are replacing the hot water pipe and valve. Now we’ve already installed the valve, which is a two outlet valve- one for the sink and one for... Read More »
