Replacing Seal On Commercial Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2013, 01:34 AM   #1
Replacing seal on commercial toilet
I'm fixing up a fraternity and I think the seal between one of the toilets and the closet bend is bad. They are the commercial flushometer type toilets. Do these toilets use the same wax seal as the normal tank toilets? Also, how do I line the toilet up correctly -- I have to keep in mind that the top of the stem of the toilet still needs to screw in to the wall-- will I have enough margin for error to do this correctly?
Does anyone know of a good online video that shows a commercial flushometer toilet being installed/ having floor seal replaced?
worthbeads is offline   Reply With Quote
Old 02-25-2013, 01:45 AM   #2
Rewards Points: 13,446
http://www.ehow.com/video_8261120_re...er-toilet.html
Old 02-25-2013, 04:48 AM   #3
DIY staff
Rewards Points: 7,174
Floor mounted toilets use wax rings---wall mounted ones use a foam gasket---
Perma-Tex or Forma Gasket is user to ensure a seal.
Tags
flushometer , ring , seal , toilet , wax
Replacing flush valve on one-peice Kohler Toilet griffin2000 Plumbing 6 01-14-2016 10:43 PM
Fernco wax free toilet seal question? masterblaster4 Plumbing 2 07-21-2011 10:56 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Replacing a toilet flange jayp Plumbing 5 06-11-2008 09:43 AM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
