Replacing Roman Tub Faucet Need To Identify - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-04-2010, 01:38 PM   #1
Replacing Roman tub faucet need to identify
I need help in replacing the Roman tub faucet on my whirlpool bath, due to the fact that the spout (which is about 9 inches long has corroded). If possible I would like to replace the trim pieces without removing the tub. Unfortunately I was not able to identify the manufacturer and wondered if anyone could help based on the following pictures:
Replacing Roman tub faucet need to identify-006.jpg   Replacing Roman tub faucet need to identify-008.jpg   Replacing Roman tub faucet need to identify-009.jpg   Replacing Roman tub faucet need to identify-010.jpg
diymichael is offline   Reply With Quote
Old 08-04-2010, 02:14 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Michael, Welcome to the Forum, Thanks for including the Pics
There must be thousands of similar faucets along with at least better quality replacements. I would check out faucets at a high end walk-in Plumbing store (not a Big Box stores)
You did not give your location. If you were in west LA I would say:
Snyder Diamond, Santa Monica, CA
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-30-2011, 12:11 PM   #3
Hi Michael, did you ever determine the manufacture of the faucet? I have the same faucet spout but with different handles. My problem is the same, old faucet with degrading plating and no access accept from the top.
DoctorJ is offline   Reply With Quote
question re replacing seats and springs in Delta faucet MegansStumped Plumbing 2 07-17-2010 10:59 PM
Roman tub faucet, no access, can it be done? HOW? Fix'r Up'r Plumbing 8 06-14-2009 05:12 PM
Shower faucet replacement - PVC replacing steel? jdm1 Plumbing 2 11-29-2008 12:38 PM
Roman Tub Faucet Removal LennyM Plumbing 3 08-02-2008 02:22 PM
Replacing Faucet for a Roman tub phibui Plumbing 8 02-14-2008 07:28 PM
