Replacing And Repairing A Tub Spout In A Tub Surround - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-10-2009, 02:26 PM   #1
Replacing and repairing a tub spout in a tub surround
Help! Recently, I have been renovating my bathroom mostly on my own. However, I asked for help to install the tub surround along with the new faucet and spout. Needless to say that was a bit of a mess. My question is this - when they installed the tub surround, they did not cut out the holes prior to gluing it on the wall. Therefore, when they went to cut the holes for the spout, they cut it slightly too big and the tub spout doesn't completely cover the hole in the tub surround. How do I fix this? The hole is on the side towards the bottom and is about the size of a regular screw head. Do I just caulk the hole? I have a four year old son that is rather boisterous in the bathtub and am concerned that water will get behind the hole and into the wall. Any suggestions??
westhawk is offline   Reply With Quote
Old 08-10-2009, 02:30 PM   #2
Remodeler
adpanko's Avatar
Rewards Points: 150
Who is the "they" that helped you install the surround? If it is a paid professional, they should take off the surround, buy a new one and put it on properly, at their expense. But if it was just a friend or something, then you're on your own. You can try to caulk the hole. Be sure to use a silicone caulk though, not latex.
adpanko is offline   Reply With Quote
Old 08-10-2009, 03:07 PM   #3
Unhappy
re: silicon caulking it is then
They are my ex-partner and my son's father So I am stuck with the tub surround that is in now
need help on repairing rotted deck support ga1990 Building & Construction 6 11-07-2008 08:32 PM
Suggestions for replacing or repairing my porch skiposwald Carpentry 5 09-28-2008 03:25 PM
