Replacing Pressure Release Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2008, 09:22 PM   #1
replacing pressure release valve
whenever I flush the toliet or turn on hose outside I here a loud humming sound coming from water main in the front yard. I was told I most likely need to replace the pressure reducing valve. Is this something that is easy to do yourself. I got some quotes up to $300.
Maureen693 is offline   Reply With Quote
Old 08-25-2008, 10:16 PM   #2
Custom Cabinet Maker
Maybe it forgot the words
I believe you will need a plumber to replace it. Might have to turn house off at the curb box to do it.
skymaster is offline   Reply With Quote
Old 08-25-2008, 11:14 PM   #3
I think someone is talking about a Pressure reducing valve. If your water supply has pressure of over 80 pounds, this is a valve that is installed to lower the pressure to the fixtures inside the house. It should also have an adjusting screw/nut on the top that you may be able to turn and prevent the noise. Some people call the Pressure Relief Valve, which is on your water heater, a pressure release valve. This valve would not cause the noise you have.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 08-26-2008, 04:21 PM   #4
my mistake
my mistake you are right it is the pressure reducing valve that needs to be replaced
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
do Pressure Reducing Valve fail? wazeaz Plumbing 5 02-10-2008 06:57 AM
Steam Generator Pressure Release Valve runlikegump Plumbing 2 02-13-2007 08:44 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
