Replacing Part Of The Main Water Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2007, 12:46 PM   #1
Replacing part of the Main Water line
its not as bad as it seems thankfully. when the guy from the water dept took out my backflow...he bridged the the pipe with two clamp type compression fittings (two halfs that come together around the pipe with screws). he told me i should replace this whenever i get a chance (no rush).
anyway....before the water meter i have a shutoff valve. i had a shutoff valve after the backflow valve which was also after the water meter. now that the backflow is no longer there, is there any need for a shutoff valve after the meter?
can i just take it out when i redo the connection?
and, when i redo the connection, i'll have a threaded male coming out of the water meter, and a pipe on the other end (to be soldered to a fitting).
what's my best way? is it simply a female to the male from the water meter, solder some pipe between that connection to the pipe on the other end with a coupling?
rgmetro is offline   Reply With Quote
Old 04-11-2007, 09:47 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
You should keep a shut off on the house side of the meter. Ball valve is prefered
Several ways to make connection, all depends on type of pipe there now.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 04-12-2007, 08:30 AM   #3
i guess i have options as far as connections......i'll have to use a female connector to go to the water meter...from that i have to put the valve and connect to pipe with a coupling...
should i solder everything first, attach the female to the water meter pipe....and make only the final solder on to the existing pipe?
i guess that would make sense.
any tips on soldering onto a brass valve...i know its a bit more tricky then just a coupling.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Main Water Line willyoldschool Plumbing 6 11-03-2006 07:01 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 02:17 AM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 07:51 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
