Replacing Outside Faucet Handle - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-27-2012, 08:53 PM   #1
Rewards Points: 137
Replacing outside faucet handle
My mother-in-law tells me that part of the handle on her outside faucet broke off. She says it hurts her hand now to turn the hose on or off (she's 84.) Can I just replace the handle or does the whole faucet need replaced? If I try to replace the handle, do I need to turn off the water inside first?
Thanks.
bucksone is offline   Reply With Quote
Old 09-27-2012, 09:11 PM   #2
Rewards Points: 13,764
No need to shut off the water. Just remove the screw holding the handle on and pull it off.
Your going to need to take it off before buying a new one. Some are square, some are splined and you need to know which one it is.
Kohler single handle shower faucet loose Liv Plumbing 8 11-13-2015 04:22 PM
Problem removing handle off of Delta Monitor 1400 series tub/shower faucet kcinsj Plumbing 35 10-22-2015 04:02 PM
Replacing shower faucet without access panel DDDIVA52 Plumbing 4 03-16-2012 07:44 PM
Kitchen faucet handle goes around 360 degrees 19mquinn79 Plumbing 2 01-31-2012 07:31 PM
Trouble replacing 2 handle shower levers matt7125 Kitchen & Bath Remodeling 2 12-02-2009 07:55 AM
