Replacing Outdoor Faucet? (with Pic) - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-26-2010, 12:26 PM   #1
Replacing outdoor faucet? (with pic)
I want to replace a frost proof outside faucet with a new one because it leaks everywhere and is beyond repair. I cut out the drywall and the current one is 10" long.
Here is a picture of the current connection in the wall. It looks like some compression fitting? Can I put some penetrating oil on this to dissolve the corrosion and unscrew it and then simply screw the new one on? Or will I have to solder it (never done that before).
Left side is 10" faucet pipe:
kwerk is offline   Reply With Quote
Old 08-26-2010, 12:31 PM   #2
fabrk8r
fabrk8r's Avatar
You can just buy a new 10" frost proof faucet like your original. Hold the center hex fitting with a wrench and grip the knurled part of the old faucet pipe to unthread...lefty loosey. Use teflon tape and pipe dope on the new one and thread it back together being careful not to twist the existing pipe.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-26-2010, 12:41 PM   #3
Wouldn't there be a good possibility of the new one ending up upside down or something if I just screw it in?
The old one is 25 years old and isn't anti-siphon so I'd need to buy a different kind.
The old one looks something like this
Old 08-26-2010, 12:56 PM   #4
fabrk8r
fabrk8r's Avatar
Tapered pipe thread is very forgiving when it comes to tightness. Turn it in until it starts to get a tight feel, then turn until it's alignment is plumb. That's why you'll want to use teflon tape and pipe dope.
10" is a standard hose bib length. You'll find one at most hardware stores.
Old 08-26-2010, 12:59 PM   #5
Use both tape and dope together?
Old 08-26-2010, 01:03 PM   #6
fabrk8r
fabrk8r's Avatar
Yes, tape threads first, keeping first 2 threads bare, then light coat of dope to lubricate and also help seal. I've never had a leak using this method.
Replacing Windows? Kyle Remodeling 13 12-17-2009 07:03 PM
Replacing sliding patio door problems marlinpuppy Building & Construction 2 02-22-2009 08:11 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 07:27 AM
Replacing Disc Brakes On 91 Toyota Corolla bobo Automotive Repairs 4 07-03-2007 06:31 AM
