Replacing Old Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-22-2013, 01:17 PM   #1
Hi
I am replacing an old sink with a new one and in the process, the metal drain pipe just broke apart due to age and deterioration. What do i do to replace this piece of pipe with a PVC catch? Tried using grips to remove the metal piece. Seems to be suck but my guess is there's adhesive or threadlocker etc. under that silver pipe leading to the copper looking coupling. Can you give me any advice?
ko0olaidguy is offline   Reply With Quote
Old 08-22-2013, 02:22 PM   #2
CitadelBlue's Avatar
Rewards Points: 97
I'm about ready to do the same type of replacement in my Dad's 1968 built house. Looks like your chrome P trap is stuck in the brass fitting which may be solder to copper pipe (can't tell because of the wall board - but that's what at Dad's house). You are going to have to get that chrome pipe out of the brass fitting and all it might need is a few shots of WD40 and some turning. It should pop off. HD/Lowes sell the replacement chrome piping.
Ken
Because you NEVER have enough room .........
See my Trailer and Hitch Thread
CitadelBlue is online now   Reply With Quote
Old 08-22-2013, 05:01 PM   #3
Rewards Points: 13,450
Just keep wiggling it back and forth to get the tapered plastic seal to come loose to remove it.
I'd replace the whole thing with PVC. It's about a $10.00 or less fix.
Old 08-22-2013, 05:08 PM   #4
Too Short? Cut it Again!
Just make sure whatever type PVC or ABS meets code where you are.
Old 08-22-2013, 07:32 PM   #5
Rewards Points: 1,860
Thats a brass trap adaptor with a brass ferrel. Wiggle the chrome part and it will come out. Keep the brass nut and use a plastic ferrel on your new trap.
The Following User Says Thank You to Ghostmaker For This Useful Post:
oh'mike (08-22-2013)
Tags
plumbing
Need help with sink drain and tailpiece nordswe83 Plumbing 5 02-21-2013 11:08 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Sink won't drain kchopper Plumbing 5 06-07-2009 09:42 PM
Replacing sink drain tube n0c7 Plumbing 7 04-16-2009 07:16 AM
pedestal sink drain stopper not working gernith Plumbing 7 04-18-2008 09:17 PM
