Old 06-30-2012, 05:24 PM   #1
replacing old Moentrol single handle shower
Hello
My old single handle Moentrol shower is leaking. Went to Home Depot and they were not very helpful. Had generic cartridge removal tool they werent positive would work and could not tell me which replacement cartridge to get. Attached is a picture of setup . Any advice on what to buy would be appreciated.
rskarma is offline   Reply With Quote
Old 06-30-2012, 06:15 PM   #2
Super Moderator
Moen Cartridge Puller - How To Use a Moen Cartridge Puller
I don't remember the cartridge number off the top of my head---
Turn off the water---you have stops right at the right and left of the mixer--but that's an old unit--so I would shut down the house rather than risk the old stops malfunctioning.
Pull off the chrome tube over the valve body---remove the brass C clip using a pair of long nose pliers.
Attach the puller==turn the nut until the cartridge is out---some times--if the old one is really stuck--you will need to reset the pulled and slip an open Crescent wrench between the tool and the valve body--
Clean the empty valve body with some fine sand paper---flush out any dirt---lubricate the opening and add your new cartridge---replace the C clip---turn on water and test before you put the handle on--
If hot and cold are reversed--turn the stem 180 degrees.
Mike
oh'mike is online now   Reply With Quote
plummen (06-30-2012)
Old 06-30-2012, 06:51 PM   #3
thanks for the info!
The Following User Says Thank You to rskarma For This Useful Post:
oh'mike (06-30-2012)
Single handle shower gets colder when turned Liv Plumbing 5 05-14-2012 06:45 PM
Replacing Shower Handles Faucetguy Plumbing 0 11-02-2011 02:45 PM
Creative shower door handle ideas?! jthomas General Discussion 2 10-11-2011 07:58 AM
Please help, Stuck cartridge,Moen single handle tub faucet, Woodpecker Plumbing 23 08-24-2010 03:42 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
