Replacing A Neo Angle With A Neo Angle - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-28-2012, 04:04 PM   #1
Replacing a Neo Angle with a Neo Angle
Hi...I am gutting and re-doing 2 bathrooms in my house. In one bathroom I currently have about a 37" Neo-Angle. I am limited on space so I'm pretty sure I can only put back in a similar shower. I am looking for one in multiple pieces because it has to go thru the door, and one of nice, heavy duty quality so that the base doesn't crack nor the walls leak, and preferably has some built in shelves with a lower one for a foot prop.
Does anyone have any recommendations, keep in mind 37" ones are somewhat hard to find as well...?
I looked at a Sterling that seemed to be of excellent quality and finish but only came in a 39" and I literally cannot accommodate two addtional inches on the other side...
kyblondi is offline   Reply With Quote
Old 06-28-2012, 04:10 PM   #2
Renovations contractor
Bonzai's Avatar
Build a tiled shower surround then the largest piece will be the shower base (other than the sheets of backer board) ... you can buy an acrylic shower base (neo angle) from most bathroom suppliers in various sizes but you'll want to make sure the drain is in the same place to minimize extra plumbing cost. With a properly built tiled surround it will not leak, you can create whatever niches, shelves, etc you care for ... as long as you have the budget. You get what you pay for ... well built, durable, sturdy and a very specific size with certain 'features' usually means custom. Depends on what you're after and what is most important as well as what you can afford ... and of course where you are located.
Home Renovations & Repairs
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
37" , heavy duty , neo angle , quality
How to read the angles on this General Angle Protractor shelzmike Tools 1 03-06-2012 10:11 AM
Is It Okay To Hang A Sheet Of Drywall On An Angle? moondriver Drywall & Plaster 12 05-01-2009 03:22 PM
replacing slab, how to replace under stairs johnny331 Building & Construction 1 01-02-2009 07:57 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 07:27 AM
Replacing Disc Brakes On 91 Toyota Corolla bobo Automotive Repairs 4 07-03-2007 06:31 AM
