Replacing Motorized Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-19-2012, 02:42 PM   #1
Replacing motorized valve
The motorized valve for my baseboard heating kicked the bucket I think last night. I am in a condo, so it is the one off the main line (hot water supplied by building) and it sounds like the motor itself is making the noise, the baseboards aren't getting heat so I assume the valve will not open because motor is toast.
The current valve is a honeywell v8043c1058 (http://www.amresupply.com/part/V8043...hSWT-N-C-2WIRE - $180) but the replacement I found locally was a Honeywell v8043g1216/u http://www.homedepot.ca/product/hone...e-valve/903029 - 80).
Will it work / replace the motor that turns the valve? Don't know how to read the specs for these, and if I can save $100 its a good day.
daconic is offline   Reply With Quote
Old 12-19-2012, 05:09 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,.... Best I can tell, the 1st one is a 24 volt valve, 'n the cheap 1 is a 40 volt valve....
Ya need the Right voltage for yer system...
General Help with replacing shut off valve under kitchen sink- Pics included amodoko Plumbing 4 04-02-2012 05:34 PM
Replacing shutoff valve undersink bketros Plumbing 1 03-16-2012 03:52 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
Need help replacing shower diverter valve magnolia Plumbing 9 07-12-2008 10:54 PM
Replacing shower valve - galvanized pipe? rjniles Plumbing 2 05-08-2008 10:29 PM
