Replacing A Major Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-18-2010, 04:26 PM   #1
replacing a major pipe
I have a pipe that runs from the flat roof on my old house ( acts as a rain water pipe from the roof) through three floors and connects to the sewer pipe under the basment floor. It is completely behind walls through all three stories of the house, however there are small access panels near it on all three floors. The kitchen sinks on the second and third floors are also connected to this central, vertical pipe. It now has developed a snaking, hairline crack above the basement ceiling but below the floor in the first floor apartment. The water from the rain (and the sinks) now leaks out and collects behind the wall in the basement where the pipe goes into the ground creating pooling water and making the sheetrock wet and moldy. I have tried various devices to soak up the water and some plumber's putty on the crack itself but I fear the solution is to replace the pipe,either a section of it or the whole thing from roof to ground. Is this as big a job as I fear, or I am letting worry run wild? can you advise? thanks
chatsford is offline   Reply With Quote
Old 05-18-2010, 07:52 PM   #2
DIY staff
Rewards Points: 7,174
We are going to need pictures of this one----you are describing a main stack vent--that is being used improperly to drain a flat roof--I think?--
Is the pipe cast iron or PVC?
More info needed-----Mike---
Old 05-18-2010, 08:09 PM   #3
Where are you located ?
In most areas its illegal to dump rainwater into the sewer pipe
Fines can be $1500 or more
The Following 2 Users Say Thank You to Scuba_Dave For This Useful Post:
MR. Mr. (05-18-2010), protechplumbing (05-18-2010)
Old 05-18-2010, 08:20 PM   #4
Rewards Points: 1,558
Legal or not, you'll need to replace the part of the pipe that is cracked. Not easy if cast iron; I think it is plumber time.
bob22 is online now   Reply With Quote
Old 05-18-2010, 08:33 PM   #5
The roof drain should be replaced entirely and kept clear of the domestic plumbing!
If the cast iron pipe is cracked in one location, it may be weak or cracked elsewhere, and cause more problems in the future.
Old 05-18-2010, 10:53 PM   #6
Rewards Points: 266
In the hospital I work at they have replaced horizontal sections of the cast iron roof drain system with PVC of the same diameter and hubless couplers.
Jim F is offline   Reply With Quote
Old 05-19-2010, 09:59 AM   #7
Rewards Points: 156
When you say it collects rain water, does it actually collect the rain water, or is it just venting out the roof and allows some rain to get in?
How big is this pipe and what kind of material is it? If it's the main stack and cast iron, you are looking at a decent amount of work here, but you don't mention any toilets flushing to it, so I am hoping that it is just a 1.5" or 2" drain that vents out the roof. If this is the case, it may not be as much work as you think, but you will probably have to touch up on your drywall skills.
Branden is offline   Reply With Quote
Old 05-20-2010, 02:23 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
depends on if it is an existing roof drain,normally it would not have other plumbing fixtures tied into it though.
plummen is offline   Reply With Quote
Old 05-20-2010, 05:25 PM   #9
Doesn't matter here if its pre-existing & goes to the sewer (not storm drain)
Its illegal, they catch it they fine you
And he clearly has stated that other plumbing fixtures DO tie into it
They've had several amnesty programs where they will assist in rerouting these systems
Old 05-20-2010, 06:20 PM   #10
plummen's Avatar
Theres many old apartment and commercial buildings in the omaha area built back in the 20s-30s that still have roof drains tied into city sewers,generally its not a big enforcement issue untill remodeling or other repairs bring the city inspector into the building.
As I said normally no other plumbing fixtures are tied in with the roof drains but it does happen.
Replacing Windows? Kyle Remodeling 13 12-17-2009 08:03 PM
Replacing a thermostat mnwalsh1 Introductions 0 11-08-2009 02:31 PM
Replacing sliding patio door problems marlinpuppy Building & Construction 2 02-22-2009 09:11 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 08:27 AM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
