Replacing Main Through Foundation - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-02-2006, 10:28 AM   #1
Replacing main through foundation
I have a Fifty year old house that has the old pipes leaking from the pigtail of the meter to the house. I can see the old pipe has been mortor into the foundation. If I replace the galvanized pipe with copper, how would I proceed through the foundation?
Jlauck is offline   Reply With Quote
Old 08-02-2006, 06:54 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Remove the old pipe and the redrill the hole with a mason bit. You may even beable to pound the old line out after you cut it, this may leave the hole big enough for new pipe to pass through
Ron The Plumber is offline   Reply With Quote
Old 08-02-2006, 08:34 PM   #3
Do I need to do anything to the new pipe that goes through the hole, like rap it with foam tape or insulation? And then should I fill the rest of the hole with morter like they did with original?
Old 08-02-2006, 08:36 PM   #4
Journeyman Plumber
Yes wrap it, and then morter it back.
Old 08-02-2006, 11:42 PM   #5
Cool
Just one more question, Ron , Does the piece of pipe going through the foundation have to be by itself or can it be part of the coil of soft tubing that is connected to the pigtail coming from the meter? The coil I have is type 'K' 3/4"
Old 08-03-2006, 01:58 AM   #6
Long-Time DIYer
Mike Swearingen's Avatar
Sounds like the right copper tubing to me, and you should be able to run it right through the foundation.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-03-2006, 08:22 AM   #7
Journeyman Plumber
Like Mike said
Yes right through the foundation, what you have is fine.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 05:32 PM
Replacing part of the Main Water line rgmetro Plumbing 2 04-12-2007 09:30 AM
Arced main lug in service panel burgeke Electrical 4 11-02-2006 12:28 PM
