Replacing Lines In Old House - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-15-2013, 01:14 PM   #1
Replacing lines in old house
Going to be replacing the water lines in my father in laws house. Taking out the galvanized and replacing with PEX. Also moving the hot water heater (they had it in the bathroom....) to a back room.
It is a small house and all of the fixtures are on the way to the hot water heater from where the water comes into the house(it's a one floor house). I was planning on running 3/4 inch PEX all the way to the hot water heater for the cold line and since the faucets are 'on the way' will branch off with tees and use 1/2 inch to each faucet shut off valve. Would do the same with the hot water as well.
Anyone see any problem with this? Don't really have the room to use a manifold system. Main water line currently comes into the house in the bathroom so is going to be pretty tight just trying to get a water shut off valve in the house and accessible, but I will do it!!
Thanks in advance for the help.
merlin66043 is offline   Reply With Quote
Old 02-15-2013, 07:50 PM   #2
Rewards Points: 582
sounds like a plan...do it...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
VIPlumber (02-15-2013)
Old 02-15-2013, 11:28 PM   #3
Trunk & branch is the type you're doing and works really well. Sounds like you're headed in the right direction.
VIPlumber is offline   Reply With Quote
Old 02-16-2013, 09:09 AM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
Depending on your code you'll also need to run 3/4 up to the toilet then branch off in 1/2 to lave shower etc,
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Tags
hot water heater , replacing water lines
Blow toward fence or house in tight location ric in alberta HVAC 16 07-03-2012 05:27 PM
Replacing fascia board on house cocean Carpentry 6 05-19-2011 05:14 AM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 10:01 PM
Replacing all the windows in a new house. Schrauf General DIY Discussions 14 08-16-2009 02:25 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
