Old 12-13-2011, 01:54 AM   #1
Replacing Lead Sleeve Soil Stack
Hi Everyone,
Joe homeowner here in dire need of assistance.
I am installing a tile floor in a small 1/2 bath after removing the old vinyl so the old flange/soil stack is not at proper height for the new floor. The house was built in 1921. To my confusion I came across a lead sleeve peened over a brass ring, which I did not encounter in my preparatory readings.
The sleeve was crooked not looking so hot so I thought I should replace it - big mistake. The ACE hardware guy (who are normally spot on) suggested I can essentially wrestle this 4"x7" lead sleeve out of the cast iron pipe and place a new one as the cast iron stack is very difficult to access (therefore cutting and replacing with PVC would be a huge undertaking).
So I proceeded to demolish the sleeve in true boob fashion including 2 full length vertical incisions through the sleeve with my sawzall thinking I could peel it out.
Obviously, I have no clue and it hasnt budged. I could probably use even more force but a crowbar and hammer has not revealed any seams I could exploit for separating the sleeve and at this point I do not want to cause more damage. I have not tired heating the sleeve as I am a bit wary of starting a fire and more frustratingly my handheld benzomatic propane torch does not stay lit well when upside down.
Now I am stuck with a non-functioning 4"x7" battered lead sleeve which I probably should have smiled at and left alone in the first place.
Can I actually remove the sleeve without tearing up the subfloor (the new floor is thankfully not installed yet) or
Is there a way to insert a 3" lead sleeve or PVC sleeve or something inside the remnants of that poor old lead sleeve to bypass this mess and install a new flange to mate with the commode (and walk away quietly)? The toilet horn has a 3" OD.
All help is greatly appreciated.
Thanks in advance!!!
nik
alllthumbs is offline   Reply With Quote
Old 12-13-2011, 06:52 AM   #2
retired elect/hvac/plumb
plummen's Avatar
picture?
plummen is offline   Reply With Quote
Old 12-13-2011, 07:01 AM   #3
What you should have done is cut it even with the floor with an ossilating saw and used a new PVC flage that has a rubber seal on the outside of it and it just slips inside of the old cast pipe.
I did the exact same thing as you did on the first one I ran across and waisted an hour fighting with it the next one took me about 2 min.
Look at the push tite style.
http://www.siouxchief.com/Resource_/...ure%201-07.pdf
Old 12-13-2011, 09:34 AM   #4
Master Plumber
Javiles's Avatar
Originally Posted by plummen View Post
picture?
couple of things you can do, need to see what you have, to get a better idea.
Javiles is offline   Reply With Quote
Tags
flange, lead sleeve, toilet
replacing parts of cast iron vent stack amakarevic Plumbing 7 03-30-2011 04:41 AM
replacing parts of cast iron vent stack amakarevic Building & Construction 1 03-29-2011 06:36 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
Replacing Lead Flange in cement floor ctrauthwein Plumbing 1 10-15-2008 06:59 PM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 03:47 PM
