Old 08-26-2012, 03:41 PM   #1
Replacing a lead to iron waste elbow?
Need to replace the lead bend.
Do I cut the cast iron past the flare/bell and just rubber couple new pvc to it?
Or should I keep the iron flare, break off the lead, and then connect the pvc a Fernco donut?
From what I read its very difficult to get the donut inserted. I dont have a whole lot of hammer swinging room as its underground.
Is the quick cut & couple way acceptable to do or should it go the donut route regardless?
brianosaur is offline   Reply With Quote
Old 08-26-2012, 04:32 PM   #2
either is fine
i have found that most of the time when someone says they are having a hard time getting donut in or band it is due to them using the wrong donut size since there are to weights of cast "thickness"
just be careful not to break next leaded joint
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is online now   Reply With Quote
Need advice on fixing a leaky elbow on waterline below sink. JeffWireman Plumbing 2 03-12-2010 12:39 PM
Replacing a Cast Iron Waste Pipe Beylah Building & Construction 0 01-18-2010 03:42 PM
toilet flange trex Plumbing 9 10-27-2009 09:36 AM
waste line in basement slab 7474 Plumbing 6 12-11-2008 07:38 AM
Replacing Lead Flange in cement floor ctrauthwein Plumbing 1 10-15-2008 06:59 PM
