Replacing Lead Flange In Cement Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2008, 04:22 PM   #1
Replacing Lead Flange in cement floor
I have a first floor toilet flange that needs replacing, it is lead and feeds into a pvc pipe below. Is there any way to replace without busting up the cement?
ctrauthwein is offline   Reply With Quote
Old 10-15-2008, 05:59 PM   #2
DIY'r
ScottR's Avatar
Just a shot in the dark, but are you replacing it because one of the slots for the closet bolts is broken? If so, this might help (available everwhere -- not just Ace) http://www.acehardware.com/sm-ace-to...i-1272614.html or this http://www.wantasub.com/bayflange.html (<-- dunno how reputable that site is tho). Easier to use that than remove the old one.
If the whole flange is shot, do you know how it's connected to the PVC? If it's just with a gasket, you could maybe wrestle it out with enough elbow grease. Otherwise you may have to chisel it or saw it out in sections (with something in the drain to prevent all that debris from going down).
Then there's this: http://www.doityourself.com/invt/6714364 I believe you just stick it in over your existing flange, screw it to the floor, and voila.. It says no tear out, but not sure if I'm reading into that correctly. Anyone else familiar with it?
BTW - If your house is plumbed with PVC waste, the flange has gotta be cast iron, not lead, though I'm surprised it's not PVC too.
ScottR is offline   Reply With Quote
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
floor flange nightmare Termite Plumbing 11 05-07-2008 10:43 PM
Toilet flange floor advice Hobb3s Plumbing 6 04-15-2008 09:41 AM
Uneven\Buldging Cement Basement Floor SSandecki Flooring 5 12-20-2005 05:06 PM
