Old 11-17-2012, 07:40 PM   #1
Replacing kitchen facet - nut stuck
I attempted to replace my facet when I was replacing the garbage disposal. Garbage disposal was easy not so for the kitchen facet. One side of the facet I could get a deep well socket which was easy. The other side has the sprayer hose with a large threaded hole and large nut. I tried spraying with WD40, I tried channel locks, I tried vise grips, I tried a crescent wrench nothing would budge it. I didn't want to totally trash it so I ended up just putting everything back together figuring I'll try later. Anyone have any suggestions?
grand_canyon is offline   Reply With Quote
Old 11-17-2012, 07:46 PM   #2
i take a hole saw just bigger than tube and cut nut off
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 11-17-2012, 08:56 PM   #3
Need one of these.
http://www.bing.com/images/search?q=...2136DE&first=1
Old 11-19-2012, 01:02 PM   #4
Thanks I picked up one at Home Depot. I will try it tomorrow or later today.
Old 11-19-2012, 01:06 PM   #5
Super Moderator
I simply use a drill and drill a section out of the nut and split off the nut with a screw driver---
oh'mike is online now   Reply With Quote
replacing box light kitchen help sportf190 Electrical 13 08-29-2012 11:08 AM
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 09:43 AM
Replacing just the kitchen cabinet doors? imola ghost Remodeling 7 02-24-2010 12:03 PM
Granite kitchen countertops replacing tile/mortar countertops - what to remove? vsheetz Building & Construction 17 06-10-2009 08:32 PM
Replacing kitchen ballast jknober Electrical 5 10-12-2008 09:48 PM
