Replacing JUST Handwheel?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-27-2009, 12:22 AM   #1
Hi there, I have a very easy question for someone with plumbing knowledge.
I have a home that was ding'd by the home inspector for having a broken handwheel on the cold water shutoff valve to the water heater.
THE VALVE IS FUNCTIONAL...I ONLY WANT TO REPLACE THE HANDWHEEL.
Can this be done? I really don't want to get into an entire valve replacement. Where can I get a spare handwheel? Looks similar to:
hookahnutz is offline   Reply With Quote
Old 07-27-2009, 01:03 AM   #2
Registered User
Termite's Avatar
Amazing what those home inspectors will ding you on.
The good news is that you can probably buy a handwheel at a plumbing supply house. Take the old one with you.
If nothing else, an entire new valve is only a few bucks at any home center...You could buy one and swap out the broken part.
Old 07-27-2009, 08:25 PM   #3
Household Handyman
Rewards Points: 1,408
The termite is correct- -on all three answers
Replacing sliding patio door problems marlinpuppy Building & Construction 2 02-22-2009 09:11 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 08:27 AM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
Replacing Asphalt w/ Cedar Shingle pbehnke Roofing/Siding 1 05-06-2008 02:28 PM
