Replacing Hot Water Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-01-2013, 03:17 PM   #1
Rewards Points: 45
Replacing hot water valve
Dishwasher went out, so bought a new one...
Now the packing on the dishwasher hot water valve leaks (wall right angle valve), so I have to replace the valve.
So I have to turn off the main, and since it's a two story house, I'll have to drain the hot water using the kitchen sink and then capture what's left in the dishwasher line (on the ground floor.)
My question is, will the cold water from the 2nd story go through the water heater and out the 1st story hot water line? Do I need to isolate the water heater (turning it off of course)?
thanks.
jeffeg is offline   Reply With Quote
Old 11-01-2013, 05:05 PM   #2
Rewards Points: 6,652
You are over thinking this. Just go to the faucet at the lowest level, open both the Hot & Cold water faucets, only after you have turned off the Water Heater & shut off the main. Then go to the highest level, and also open both the Hot & Cold water taps.
When they are finished draining, just replace the valve, then reverse the process. Remember to keep the taps open, to allow any air that came into the system, to be pushed out, but only by slowly turning on the main water valve.
When you are done getting the air out of the system, you will be fine after that.
The Following User Says Thank You to gregzoll For This Useful Post:
jmon (11-01-2013)
Old 11-01-2013, 05:06 PM   #3
Rewards Points: 12,794
Just shut off the main.
Old 11-01-2013, 06:22 PM   #4
Rewards Points: 45
done!
yes, I "overthunk" it, it all went well. About 1/2 gallon of water came out, I was expecting more... thanks!
The Following User Says Thank You to jeffeg For This Useful Post:
jmon (11-01-2013)
Old 11-01-2013, 06:26 PM   #5
More only comes out if you have a bad shutoff somewhere.
Replacing Washing Machine Water Shutoff Valve aimforthenail Plumbing 11 10-04-2013 10:41 AM
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Leaky ball valve at incoming water line Bipin1948 Plumbing 5 10-03-2011 06:21 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
