Replacing "guts" Of A Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-01-2009, 10:23 AM   #1
Replacing "guts" of a toilet
Hey,
I had some water issues a few months back that shot sediment into all of the pipes in my house, which blocked all of the water from flowing into all areas of the pipe. I drained and cleaned all of the pipes out and the water works better then ever. This is except the toilets in my house. I believe the sediment got into the "guts" (for the lack of a better term) of the toilet and needs to be replaced.
Being a new home owner, I was not sure how involved this project would be or should I call on a professional? I am looking for any and all suggestions on how to fix this without buying anything. Thanks everone.
Nick
BBramabull is offline   Reply With Quote
Old 05-01-2009, 12:06 PM   #2
Oldie but Newbie
Originally Posted by BBramabull View Post
Hey,
Nick
There are really only two working parts...the flap and the valve assembly that controls the water level, and these are readily available in kit form at hardware stores and easy to replace. Both are located in the tank.
Note that there are different styles of valve assemblies, but most of them are interchangeable. Toilets are fairly universal in their design.
What is the nature of the problem with the toilets? If it has to do with the speed at which they refill or the operation of the valves that stop the water when the tank is full, then you have probably guessed correctly.
LookoutRanch is offline   Reply With Quote
Old 05-01-2009, 12:10 PM   #3
Yes, that is what the major problem was. I have not done much work with plumbing or toilets, so I didnt want to start this project and get over my head.
I will check this out and let you know how it works out.
Thanks!
Old 05-01-2009, 02:11 PM   #4
Oldie but Newbie
If you haven't done so already, you might want to consider installing one of these to reduce the chances of sediment build-up in the future.
You can find them at Lowes or Home Depot (etc.) or online. There are several look-alike brands (GE, Culligan, etc.) that use the same replaceable cartridge filters.
http://www.waterfilters.net/culligan...ings/HD950.htm
Old 05-01-2009, 02:31 PM   #5
Go get a Fluidmaster kit at just about any hardware or big box store. It comes with installation instruction. I just installed one yesterday it took less than a half hour.
hayewe farm is offline   Reply With Quote
Old 05-01-2009, 04:24 PM   #6
Custom Cabinet Maker
Amen on the Fluidmaster, get the GRAY one not brown. Gray is anti siphon, install just the same, real EZ.
skymaster is offline   Reply With Quote
Old 05-01-2009, 07:34 PM   #7
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Being a plumber, I'd have to say that installing a new Fluidmaster fill valve is one of the easiest DIY projects for a newbie to start off on. Go for it. "You can do it....we can help." Wait...didnt someone say that on TV once?
JDC is offline   Reply With Quote
Old 05-07-2009, 08:59 AM   #8
Thanks everyone! I am gonna hit the project this weekend. I have both toilets to do. I do have a water filter. The owner before never changed the filter so not only did I have build up but the water pressure was down to almost nothing! I will let you know how smooth it goes.
Thanks again. Now i know where to go for help!
Rusted-out closet flange found when replacing toilet; what to do? kevind Plumbing 16 09-23-2011 08:00 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
replacing toilet...basic questions mcvane Plumbing 4 01-16-2009 10:11 AM
Replacing a toilet flange jayp Plumbing 5 06-11-2008 09:43 AM
Replacing a Toilet dandgluna Plumbing 8 07-10-2006 10:09 PM
