Replacing Gas Shut Off Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2011, 01:38 PM   #1
replacing gas shut off valve
My 1/2" shut off gas valve that feeds my water heater is leaking-(soap bubbles)- it's old and needs to be replaced- If I just replace the valve- do i need to replace the black iron pipes that feed into it? Below the valve is a union- then above the valve is another foot long piece that goes into an elbow
mongo1968 is offline   Reply With Quote
Old 11-29-2011, 04:02 PM   #2
UA Local 85
coolv's Avatar
Not necessarily if you put everything back together and their are no leaks you should be fine. Clean the threads of whatever you disconnect and apply thread compound and you should be ok.
coolv is offline   Reply With Quote
Leaking shut off valve, am I that inept??? ChrisDIY Plumbing 12 07-28-2012 08:52 PM
Toilet Water Shut Off Valve anelson Plumbing 1 07-11-2011 10:42 AM
Help? Replacing water shut off valves frozenmama Plumbing 4 09-28-2010 07:17 PM
shut off valve under sink mathmama Plumbing 7 05-16-2010 06:27 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
