Replacing Flapper In Old Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-10-2010, 11:22 PM   #1
Rewards Points: 206
Replacing flapper in old toilet
I have a rental house with an old toilet that was leaking today. I went to fix it and noticed that the washer underneath the bolt that holds the tank to the toilet, was cracked. Attached to the bolt was some sort of flapper extender which attached the flapper to the bottom of the tank, because there is no other place to attach the flapper to. Usually, there is a pipe that the water goes in to fill up the tank and the flapper attaches to that pipe. This toilet has that pipe built right into the tank. I am attaching a picture of the inside of the toilet. I appreciate any help. Thanks
joeg679 is offline   Reply With Quote
Old 11-11-2010, 07:15 AM   #2
Fluidmaster makes a standalone flapper the gets glued to the old seat(with their adhesive putty). They work pretty well if you thoroughly clean the old seat, and make sure it is DRY.
Old 11-11-2010, 07:33 AM   #3
Rewards Points: 1,418
Does the flapper extender still work by itself?
You might try re-using the flapper extender but adding new washers above and/or below it to seal the bolt against the flapper extender and seal the flapper extender against the tank bottom.
You really don't want to screw down the tank bolts to the back of the toilet bowl all that tight. Ideally the sequence goes: bolt, rubber washer, *, tank bottom, metal washer, nut, bowl rear, rubber washer, metal washer, nut.
If you don't have the middle nut, you need to crank up the lower nut more tightly to achieve a seal up above.
But the tank must rest directly on the bowl rear, without the middle nut as the load bearing surface holding tank and bowl slightly apart. It may be necessary to purchase a more shallow nut separately for the middle nut or take a nut that came with the bolt kit and sand it to become shallower.
* -- flapper extender has rubber washers on both sides.
Old 11-11-2010, 09:06 AM   #4
Rewards Points: 206
The flapper extender is broken. I can't seem to find one online, I haven't tried a store yet. Would a plumbing supply place have it there or are they usually special order? Also, what is the proper name? Thanks a lot.
Old 11-11-2010, 04:29 PM   #5
Homerepairguy's Avatar
Rewards Points: 990
This link might help you out:
http://homerepair.about.com/od/plumb...et_flap555.htm
HRG
Homerepairguy is offline   Reply With Quote
Old 11-11-2010, 08:46 PM   #6
Rewards Points: 206
Thanks guys. I actually found the piece that I need at a plumbing supply place. It was the last one they had.
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 08:54 AM
Toilet flapper keeps flipping backwards msammut Plumbing 2 07-04-2008 07:08 PM
1 piece toilet leaks at brass gasket below flapper texaslady Plumbing 1 10-02-2007 03:40 PM
Replacing a Toilet dandgluna Plumbing 8 07-10-2006 11:09 PM
