Replacing/Fixing Leaky Shutoff Valve Under Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-15-2010, 05:32 PM   #1
Replacing/Fixing leaky shutoff valve under sink
Hello Everyone,
I'm trying to deal with a leaky shutoff valve beneath the bathroom sink and ran into some problems.
First, I can't seem to remove the plastic cap coverings on the valve knob. I'd like to disassemble the front end and inspect the washers and maybe reseat them in case they're still usable. I've tried to pry and pull them off with no luck - I don't want to break them. Any suggestions?
Skip this and just replace the whole valve?
Jeff
JeffWireman is offline   Reply With Quote
Old 02-15-2010, 05:35 PM   #2
Remodeler
adpanko's Avatar
Rewards Points: 150
just replace the whole thing
Don't bother trying to repair it. For under $10 you can buy a new shutoff. Use a compression connection and you're done in under 20 minutes start to finish and no soldering.
adpanko is offline   Reply With Quote
Old 02-15-2010, 05:43 PM   #3
Household Handyman
Rewards Points: 1,408
"adpanko" is correct! I tried once to take one of those plastic stop valves apart, with no luck. I keep stop valves in my trailer and I spent as much time fooling with that %#*@ valve than it did to replace it. The only possible problem--you may have to turn off the main water supply--just a bit more time. David
Old 02-15-2010, 05:56 PM   #4
Thanks to both.
Looks like the easiest way to go.
I'm more worried about getting the nut on the valves rear loose from the incoming main line which I think is PVC. The valve nut is metal. Looks like someone may have gotten paint across the junction which is going to make it a little harder to get off.
Any major risk in cracking the main PVC?
Old 02-15-2010, 11:30 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
if its just the packing thats leaking youve got nothing to lose by trying to tighten packing nut under handle first,you dont need to remove handle to do this.
plummen is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Looking for bathroom sink shutoff valve solution tigereye Plumbing 2 01-23-2010 10:36 PM
Leaky air valve on furnace dcam HVAC 0 11-01-2009 07:36 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 01:28 AM
