Replacing A Faucet... - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-09-2013, 09:06 PM   #1
Question
Replacing a faucet...
I bought a new faucet this weekend to replace the old one that originally came with this house 20+ years ago. The instructions with the new faucet were incredibly vague, so I've been following YouTube videos and the like to try and install this thing. Unfortunately I've hit a snag... When replacing the popup drain, all the videos show the removal of the p trap by turning a couple of nuts. I don't have any of those (pic below). How do I go about removing this?
VaBookworm87 is offline   Reply With Quote
Old 03-09-2013, 09:15 PM   #2
Rewards Points: 13,960
You have a glued trap, I can not think of a single good reason why it's that way.
If it was mine I'd cut it out and replace it with one like this.
http://www.bing.com/images/search?q=...ectedIndex=299
Going to have to cut off the pipe closest to the wall and add an adaptor.
http://www.bing.com/images/search?q=...lectedIndex=47
jaydevries (03-09-2013)
Old 03-09-2013, 10:10 PM   #3
Rewards Points: 83
I like the glue in. It never leaks
You might be able to weasel it out of there by loosing the two nuts and lifting it up enough to unscrew the top drain
mech_gui is offline   Reply With Quote
Old 03-09-2013, 10:11 PM   #4
Rewards Points: 83
Like this...
Old 03-09-2013, 10:41 PM   #5
I'll give that a try Thanks!
Old 03-09-2013, 10:54 PM   #6
Rewards Points: 83
That is , of course the top part is threaded. if it is one piece then you will have to do what Joecaption said.
Tags
faucet , p trap
Changing faucet - reverse osmosis adapter grand_canyon Plumbing 4 11-20-2012 10:29 PM
Vibrating Pipe after replacing washer in faucet mikegoa Plumbing 2 09-19-2012 08:22 PM
Need help with replacing leaky, rusting outdoor faucet, please. Nina2 Plumbing 12 07-06-2012 03:00 PM
Replacing Section of Feed Line When replacing kitchen faucet??? spyboy Plumbing 5 03-21-2011 02:57 PM
Replacing bath tub faucet handles dave6k Plumbing 4 02-03-2010 07:55 PM
