Replacing Dishwasher, No Water Shutoff - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2011, 11:37 AM   #16
the "pvc" goes to an elbow where 3/8 copper is run to the dishwasher inlet, i havent purchased the valve yet, any recommendations?
sustorm is offline   Reply With Quote
Old 04-05-2011, 11:43 AM   #17
Owner
LateralConcepts's Avatar
Can you take a picture of the existing connection and transition from PVC to copper. I'm having a hard time visualizing how it's set-up now.
You'd actually be better off just T'ing off the water supply for the kitchen faucet. Use a 3-way valve. 1/2"x3/8"x3/8" compression angle stop. Then of course you'd have to cap off the connection at the water heater.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 04-05-2011, 11:56 AM   #18
sorry, I cant, I wish i could. the pvc just comes down the inside of the wall to a 90 and at the 90 the pipe is copper, i believe there might be a fitting similar to this at the 90, then the copper is run through the wall and under the dishwasher straight to the inlet and that looks similar to the other picture.
FYI the below pictures are not mine and were retrieved from google images
Old 04-05-2011, 02:01 PM   #19
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Originally Posted by LateralConcepts View Post
PVC is used all the time.
I have to question this statement. My understanding that if PVC is used with hot water it will soften and bulge. And over time it will burst. Have I been misled?
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 04-05-2011, 02:24 PM   #20
I ask the impossible!
Rewards Points: 698
In that case, just open the kitchen faucet (burp it) then shut it back off. It'll air lock as long as there are no leaky valve in the house. You might get a little water. Just work quick. What kind of valve did you end up getting? How do you plan to connect it to the PVC? or CPVC? Whatever it is..
Funny story... In my crawl space I had to cut a copper line feeding the toilet upstairs, I was soldering on a threaded fitting so I could put in a shutoff valve and do a CPVC jog where the pipe was route through where I'm going to install a beam. I made my cut in the copper pipe having shut off the house water supply and went to the store to get my CPVC fittings.
When I came back, water was still coming out. I had left faucets openning, so the whole thing was siphoning water out of the hot water heater. When I shut off the faucets, the water stopped and I was able to solder my fitting on.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 04-05-2011, 07:24 PM   #21
Owner
Yes, I think you've been mislead. PVC is perfectly acceptable unless the AHJ (inspector/code) says otherwise. Personally I think CPVC is far more prone to becoming brittle over time. And PEX.. IMO is far superior to both.
http://www.ppfahome.org/pvc/index.html
"What are the temperature limitations of PVC pipe?
The maximum use temperature for PVC pressure pipe is 140 degrees F. PVC DWV piping readily withstands the hot and cold water discharges that are normally associated with plumbing fixtures.
Lateral
(208) 818-8241
Old 04-06-2011, 02:20 PM   #22
Rewards Points: 698
PVC is fine for DWV at hot water temperatures because DWV is not presurized.
Using your same source, here is their page on CPVC:
http://www.ppfahome.org/cpvc/index.html
They rate CPVC for 400 psi at room temperature and 100psi at 180 degrees F.
http://www.ppfahome.org/cpvc/faqcpvc.html
CPVC systems conforming to ASTM D2846 are rated for continuous service at 100 psi and 180 degrees F and are marked accordingly. The model codes recognize CPVC's capability to handle short-term pressure/temperature excursions beyond these levels. Therefore, CPVC is well suited for usage as T/P relief valve discharge lines, evidenced by its faultless service history over the past two decades in this application.
You were also quoting from their FAQ page:
http://www.ppfahome.org/pvc/faqpvc.html
Further down on that page they show a chart for converting pressure ratings by tempeature. The pressure rating for PVC is half of its room temperature presure rating when it carries water at 130 degrees F.
Looking on Home Depot Schedule 40 PVC is rated at 480 PSI. Typical city water pressure operates around a 50 psi ballpark, but you have to consider that water hammering can result in pressure spikes of 250 to 400 psi.
http://www.siouxchief.com/Resource_/...FAQ%204-04.pdf
Old 04-06-2011, 02:33 PM   #23
Owner
[/font]
Not really sure what you're trying to prove. Again, PVC is perfectly acceptable for water piping (hot & cold). I've seen miles and miles of the stuff over the years. Obviously we all know that different areas have different codes.
If water is spiking to 200+psi, you will have far bigger problems than what kind of pipe is installed. Water pressure shouldn't exceed 80psi. 75 is about ideal. Regardless of what the pressure from the city is; if excessive, it's the responsibility of the homeowner to regulate the pressure with a PRV.
Lateral
(208) 818-8241
Old 04-06-2011, 03:52 PM   #24
Rewards Points: 698
I guess I'm speaking to theory and you're speaking to practice and the reader can take the info and decide for themselves, within the range of what is acceptable to their particular AHJ.
Old 04-08-2011, 12:56 PM   #25
just to clarify, the pipe was CPVC, and thanks for all of your help, i turned off the hot water inlet, ran the kitchen sink until HW stopped coming out and then disconnected the old dishwasher and only lost a small bit of water, thanks again!
conversion of portable dishwasher to stationary one grimsbyman Plumbing 15 02-13-2014 10:45 AM
Lost Hot water pressure brile Plumbing 11 11-28-2010 02:59 PM
Replacing Dishwasher - Water Valve Help? BCreed025 Plumbing 1 07-26-2010 04:01 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
