Replacing Dishwasher, No Water Shutoff - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-04-2011, 11:59 AM   #1
Replacing Dishwasher, No water shutoff
Hi, my wife and I just purchased a 1960's ranch home and we are going to replace the dishwasher. The water supply for the dishwasher is run straight off of the gas hot water heater and there is not a shutoff valve between the two. My plan to disconnect the water line is the following:
  1. shut off the cold water inlet valve to the hotwater heater
  2. turn off the hot water heater
  3. Run all of the hot water facuets to empty the HWH
  4. disconnect dishwasher water supply line, catch any remaining water in the pipe
  5. install pipe plug on dishwasher water line until new dishwasher comes
  6. turn the water and HWH back on hope it doesnt leak
Is this the best way to go about this removal of the dishwasher? I am hoping to have minimal water issues. I have to get the old dishwasher out and ready for removal before the new dishwasher comes so Sears will take it with them.
Thank you for taking the time to read this.
Charlie
sustorm is offline   Reply With Quote
Old 04-04-2011, 12:03 PM   #2
Rewards Points: 760
While you have the water off, can you put a shut-off valve in the line, so you don't ever have to go through this again OR if the dishwasher ever leaks, OR needs replacing again?
AandPDan is offline   Reply With Quote
Old 04-04-2011, 12:04 PM   #3
That certainly can be done, good thought, thanks. Other than that, safe plan?
Old 04-04-2011, 12:06 PM   #4
Oldguy
Rehabber's Avatar
#1,2, and 3 arejust fine, but add a shutoff valve at the beginning of the supply line.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 04-04-2011, 12:20 PM   #5
okay thanks will do
Old 04-04-2011, 01:26 PM   #6
Owner
LateralConcepts's Avatar
The water supply for your HWH is most likely 3/4". I'm guessing copper? How is the existing transition made to the dishwasher supply? If it's a saddle valve (needle valve), get rid of it! Install a 3/4" x 1/2" Tee, a 1/2" x 3/8" compression stop, then a stainless steel braided supply line for your dishwasher.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 04-04-2011, 01:35 PM   #7
there is a T off of the main HW outlet that goes to a pvc line down the wall. That goes to an elbow where the copper line runs straight to the dishwasher inlet.
Old 04-05-2011, 11:09 AM   #8
Rewards Points: 3,130
I hope you meant CPVC. Regular PVC is not for use with hot water.
Old 04-05-2011, 11:15 AM   #9
Owner
PVC is used all the time.
Lateral
(208) 818-8241
Old 04-05-2011, 11:16 AM   #10
do i have to completely drain the hot water tank, or just shut off the inlet and run some water out to releave the pressure? When I disconnect the dishwasher line, is it going to run like a hose?
Old 04-05-2011, 11:20 AM   #11
Owner
No. Just shut off the valve to the cold water inlet, open up a faucet. If possible, open one that's lower than the dishwasher connection.
Lateral
(208) 818-8241
Old 04-05-2011, 11:21 AM   #12
Experienced
Jackofall1's Avatar
Just turning the HW supply off is fine, with all valves closed it will be air locked, you may get a bit of water out of the line to the DW, when you disconnect it.
Mark
Old 04-05-2011, 11:26 AM   #13
the dishwasher inlet is probably the lowest hot water line and the home is on a slab. Do I open a faucet and leave it open, or do i just disconnect the dishwasher line, catch that water and due to the air lock, and put my valve/pipe plug on the line until I install the new dishwasher
thanks for the help
Old 04-05-2011, 11:31 AM   #14
Experienced
Jackofall1's Avatar
You should be fine as long as no one opens a valve when you have to DW disconnected and there isn't a leaky hot water tap.
Being that is the lowest point even if you drained the piping you would still have water in the line.
As long as your system is air/liquid tight you should be fine. Make sure you install a shut off valve to the DW when you have it apart.
Mark
Old 04-05-2011, 11:32 AM   #15
Owner
thanks for the help
In that case, just open the kitchen faucet (burp it) then shut it back off. It'll air lock as long as there are no leaky valve in the house. You might get a little water. Just work quick. What kind of valve did you end up getting? How do you plan to connect it to the PVC? or CPVC? Whatever it is..
Lateral
(208) 818-8241
conversion of portable dishwasher to stationary one grimsbyman Plumbing 15 02-13-2014 10:45 AM
Lost Hot water pressure brile Plumbing 11 11-28-2010 02:59 PM
Replacing Dishwasher - Water Valve Help? BCreed025 Plumbing 1 07-26-2010 04:01 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
