Replacing Deep Well Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-06-2011, 04:15 PM   #1
The new pump that arrived has an outlet opening for 1 1/2" pipe thread, I have 1' pipe. The motor and volume is approximately the same as the one that went out. Do you think there will be an issue retrofitting with a reducer and what do you think is the best way to do it?
snakedaddy is offline   Reply With Quote
Old 10-06-2011, 05:07 PM   #2
DIY staff
Rewards Points: 7,174
PVC or steel pipe?
Old 10-06-2011, 06:28 PM   #3
Originally Posted by oh'mike View Post
PVC or steel pipe?
pvc and its 1 1/4" on the outlet of the pump, not 1 1/2"
Old 10-06-2011, 07:09 PM   #4
Rewards Points: 582
your local supply house will have an 1 1/4 male x1" insert fitting brass to hook up to your plastic pipe....
Old 10-06-2011, 11:51 PM   #5
thanks guys,
got the reducer, spliced the wires, heat shrunk and tapped all the junctions. Got a cpl of buddies coming in the morning to give me a had dropping the pump down in the hole.....wish me luck
Old 10-07-2011, 08:35 AM   #6
DIY staff
Good luck on that!!!
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 03:56 AM
replaced flooded convertible jet pump, pressure will not go over 30 lb. dcreech Plumbing 4 09-18-2011 10:14 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 07:55 AM
Replacing basement sink pump kornfein Plumbing 0 04-23-2010 12:56 PM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 01:04 PM
