Old 02-23-2013, 04:15 PM   #1
Replacing cast iron sewer pipes with pvc?
I just bought a house and it has cast iron sewer pipes. I want to replace it with pvc. All the pipes i want to replace are accessible and easy to get to from the basement. Do i just put pvc pipes where the cast iron is? Do i cut the cast iron near the start and end of pipe and attach pvc? If so, how do i connect the pvc to the cast iron? Should i use the same size pvc as the cast iron?
The pipes are in a relatively small space so i could put pictures up, but im not quite sure how to. If someone would be kind enough to respond to this and be able to help me, and explain how to add a picture it would be greatly appreciated!
Thank you!
kyle.arcand is offline   Reply With Quote
Old 02-23-2013, 04:44 PM   #2
call me E
TheEplumber's Avatar
Try this link for photo "how to" http://www.diychatroom.com/f98/
Once you get a couple shots up, we'll get you all the info you need.
There are transition couplings for every situation so no worries there and your project sounds pretty straight forward
Old 02-23-2013, 06:00 PM   #3
MarginallyQualified
Why? Is something wrong with them?
Old 02-23-2013, 06:03 PM   #4
http://www.fernco.com/plumbing/flexi...tock-couplings
Old 02-23-2013, 06:12 PM   #5
i occasionally still use cast iron so i agree with tarhill
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 02-23-2013, 09:32 PM   #6
if it ain't broke don't fix it.
Old 02-23-2013, 09:59 PM   #7
747
registered
747's Avatar
PVC some fern co correct size boots and some breeze clamps. You need something to cut cast iron with. I also say if its not broke don't fix it. You still see cast iron used today. Especially in second floor to basement drain pipe application for quietness
747 is offline   Reply With Quote
Help me! Cast Iron Leak (Picture) meandiet Plumbing 8 08-14-2011 05:41 PM
replacing/altering cast iron supply & return lines? jeffro83 HVAC 5 05-12-2011 07:14 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 07:38 AM
cast iron drain pipe? sharp Plumbing 3 10-14-2009 12:52 PM
working with cast iron ericadami Plumbing 9 11-30-2008 01:45 PM
