Replacing Cartridge In Mop Sink Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2014, 08:51 AM   #1
Rewards Points: 79
Replacing Cartridge in mop sink faucet
I have cartridge out but can't remember if the spring and cap rubber washer goes into the hole in bottom of assembly with spinrg in hole and rubber cap washer on top or reverse, washer in hole and rubber cap on top of spring. As we say Down South, HEP.
Dumb or dumber, not sure.
vabear is offline   Reply With Quote
Old 03-17-2014, 09:43 AM   #2
Who's the manufacturer? Can you post a picture of the cartridge/stem?
Ishmael is offline   Reply With Quote
Old 03-17-2014, 12:34 PM   #3
Rewards Points: 79
Replacing Cartridge
Don't have my digital camera available at this time. Believe it is a Delta, about 2"-21/2" long, plastic body and brass shaft. Well has a hole in bottom, for water flow I assume and that either the spring with rubber cap on top goes into the hole or the reverse. I am thinking now that the spring goes into the hole and the cartridge compresses the spring and the rubber cap moves across bottom of the cartridge.
Old 03-17-2014, 12:40 PM   #4
Rewards Points: 14,306
http://www.bing.com/images/search?q=...arts&FORM=IGRE
Pick one.
Old 03-17-2014, 01:05 PM   #5
What you are describing sounds correct for a delta style faucet. Spring goes in the hole, rubber washer on top, then the cartridge which spins on and off.
broox is offline   Reply With Quote
The Following 3 Users Say Thank You to broox For This Useful Post:
Ishmael (03-17-2014), SHR Plumber (03-17-2014), vabear (03-17-2014)
Old 03-17-2014, 06:23 PM   #6
Rewards Points: 79
Replacing Cartridge
Thanks, I have it right and went a purchased a new cartridge, BUT, it is too long so as my Mother in Law once said, no project is complete without at least two trips to the hardware store, So True.
Old 03-18-2014, 09:52 AM   #7
Rewards Points: 79
Delta Crtridge Replacement
New and correct cartridge in and all is well.THANKS TO ALL.
replacing shower cartridge crankbait09 Plumbing 27 07-20-2012 07:37 PM
Replacing 2 handle faucet with single handle faucet vcheez Plumbing 6 10-19-2011 10:26 AM
Help replacing Kitchen Faucet (no nut under sink) deathandgravity Plumbing 5 12-09-2010 10:19 PM
Replacing Price Pfister cartridge bath faucet robwallis Plumbing 2 03-12-2009 10:29 AM
cartridge faucet problem. drewhart Plumbing 4 01-15-2009 10:49 AM
