Replacing Bathroom Sink - Questions About Tools, Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-07-2014, 10:43 PM   #1
Replacing bathroom sink - questions about tools, drain pipe
I'm replacing my bathroom sink and vanity & have questions about the drain pipe (I already have info about the water supply lines):
I'm going to use new PVC piping; assuming the following: Wall pipe --> drain pipe --> p-trap --> tail piece --> pop-up assembly
Therefore, need to buy p-trap kit and pop-up assembly (unless, of course, need extensions)? Anything else in terms of pipes?
How do you know what diameter size p-trap kit and pop-up assembly to buy?
If 2 pipes have the same diameter, how are they connected -- I know slip nut but does one pipe have to fit inside another?
If one pipe is smaller diameter than other, I have to use a reducing slip nut w/ a reducing rubber bishing?
Assuming I should buy a bunch of extensions, elbows and slip nuts and return the ones not used?
Good place to buy all this?
metazone is offline   Reply With Quote
Old 02-08-2014, 06:58 AM   #2
DIY staff
Rewards Points: 7,174
Most faucet sets come with a pop-up---
All vanity drains are 1 1/4"---new vanities tend to be taller than the old ones--so this is what you need---
(all 1 1/4")
One-tailpiece extension-one P-trap set---possible a 1 1/2" nut and a 1 1/2" to 1 1/4" reducing washer washer to go into the wall---
What size is the wall pipe ? That threaded fitting is called a 'trap adapter'---if it's 1 1/4" you are not going to need that reducing washer and larger nut---but you will need another 1 1/4" nut and washer.
metazone (02-08-2014)
Old 02-08-2014, 12:17 PM   #3
Thanks, Mike. I'm trying to gather all the info I need for when I get the time to do this (I bought the vanity w/ sink + the faucet). I've watched a few videos on youtube and, in another post, someone said that I would need primer and glue. In the videos, I haven't seen anyone using glue or primer so ... And, I am still unclear about how 2 pipes will connect if they're the same size: e.g. if I cut a 1 1/4" PVC pipe and I need to connect it to another 1 1/4" PVC pipe, I assume just one of the pipes has to be threaded? And I just connect them by using a washer and a slip nut that goes on the pipe with the threads? The pipe without the thread doesn't fit into the pipe with the thread?
Old 02-08-2014, 08:07 PM   #4
DIY staff
Take your self to the store and look at the parts---the P-trap and extension are larger at the top so the end can slip inside--the tighten up with the plastic nut---This will also give you some adjustment as the 'pocket' is deeper than needed---
Old 02-09-2014, 12:41 AM   #5
OK. And what about gluing? I've watched some videos on bathroom sink drain pipes and didn't see anyone use glue. Is it needed?
Old 02-09-2014, 01:41 AM   #6
DIY staff
No glue needed---you will need a small tub of plumbers putty to use under the top chrome ring of the pop-up.
Old 02-09-2014, 08:55 AM   #7
Rewards Points: 13,300
If it was glued there would be no way to disassemble it to cleanout the trap and drain.
Old 02-09-2014, 10:55 AM   #8
Rewards Points: 1,770
You will need to glue on a trap adapter at the wall if you do not currently have one.
http://www.orschelnfarmhome.com/Orsc...Feg-MgodOVkAWA
The Following User Says Thank You to Ghostmaker For This Useful Post:
oh'mike (02-12-2014)
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 03:04 PM
simple question regarding kitchen sink drain donkeyk Plumbing 6 05-31-2012 10:32 AM
Drain For Garage Sink & Standing Pipe Fire4Effect Plumbing 4 09-29-2011 12:16 AM
How to fix bathroom sink drain pipe ? cprao Plumbing 9 02-27-2010 09:15 PM
Drain Pipe about 20 Inches to the right of Vanity Sink mark2741 Plumbing 2 12-16-2009 11:32 AM
