Old 02-03-2010, 08:11 PM   #1
Replacing bath tub faucet handles
I am remodeling my bathroom and I have a one handle bath tub faucet and I would like a new handle and new spout. Will the existing faucet valve behind the wall work with any new handle or do I need to replace the valve as well?
Thanks.
dave6k is offline   Reply With Quote
Old 02-03-2010, 08:20 PM   #2
Thanks.
is it a delta valve or do you know the make
Walttheplumber is offline   Reply With Quote
Old 02-03-2010, 08:34 PM   #3
The cover plate says Moen. The valve has nothing on it that I can tell. Here is a photo.
Old 02-03-2010, 08:53 PM   #4
you have plenty of info if you have cover plate. you can go to most home centers or plumbing suppliers and get the moen trim kit of your choice. they are fairly simple to install. pay close attention to the scald guard adjustment..make sure you specify whether it is a shower only or tub shower. i have had people get thier own stuff and are disapointed when they find out they got the wrong kit
Old 02-03-2010, 08:55 PM   #5
the valve you showed has a hot and a cold shut off. before you put trim kit on make sure they are both open.use flat head screwdriver.
replacing bathtub faucet cflo Plumbing 4 05-05-2009 12:10 AM
Replacing Price Pfister cartridge bath faucet robwallis Plumbing 2 03-12-2009 11:29 AM
Shower faucet replacement - PVC replacing steel? jdm1 Plumbing 2 11-29-2008 12:38 PM
how to remove roman bath faucet? tarheelblue Plumbing 1 06-07-2008 07:38 PM
Replacing Faucet for a Roman tub phibui Plumbing 8 02-14-2008 07:28 PM
