Replacing Bath Tub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-24-2014, 04:29 PM   #1
I'm trying to replace my tub drain and can't get the old one removed. I'm using the "Superior Tool" tub drain extractor, but the old drain won't budge. Any suggestions would be appreciated.
Gerard
gerardswork is offline   Reply With Quote
Old 05-24-2014, 04:31 PM   #2
DIY staff
Rewards Points: 7,174
Is the chrome ring turning at all?
Old 05-24-2014, 04:32 PM   #3
Barely...maybe a few mm.
Old 05-24-2014, 04:36 PM   #4
Do you think it's because my ratchet is so close to the tub? Should I get an extension?
Old 05-24-2014, 04:45 PM   #5
DIY staff
If it is only moving a little bit--you are,most likely, moving the entire drain shoe---which means the drain set is going to leak ---do you have access from below or from the back of the plumbing wall?
Are you removing and replacing the entire drain and over flow?
Old 05-24-2014, 04:48 PM   #6
I'm only removing the drain as the stopper Jo,longer was working....no access from behind or below.
Old 05-24-2014, 04:55 PM   #7
DIY staff
You have a stuck chrome ring---forcing it to turn will bend up and otherwise wreck the drain set---it might be in trouble now---are you on a slab? what is behind the plumbing wall---???
Old 05-24-2014, 04:59 PM   #8
It's on the second floor...I have no intentions of getting to it from below...how do I unstick the drain?
Old 05-24-2014, 05:05 PM   #9
DIY staff
I'll have to leave that for someone else---saw splitting the ring is the only way I know--and that has the risk of damaging the drain shoe---so being prepared to open up the walls or ceiling must be an option---if not--perhaps someone has discovered a solution---be patient---someone will chime in soon---
Old 05-24-2014, 05:38 PM   #10
Ok...thanks for your feedback. I went out and bought a 5 inch extension for the ratchet...still won't budge. It's like the drain become one with the pipe...very frustrating. Any and all suggestions are welcome.
Old 05-24-2014, 05:57 PM   #11
Mad Scientist
I almost always have to cut those out with a dremel. I think I've run across maybe 1 that I was actually able to unscrew. If you're *very* careful, you might not destroy the drain shoe in the process.
I'd still be prepared for the possibility of having to open up the wall.
McSteve is offline   Reply With Quote
Old 05-24-2014, 07:10 PM   #12
DIY staff
I have only run into a few that wouldn't unscrew---However,I am always prepared to replace the drain set,just in case----
Old 05-24-2014, 09:31 PM   #13
Ok...I'll throw this one out there for the sake of a conversation. Was Googling this one around and found a product that does not require you to take out old drain. It's called a Universal Nufit. Anyone have any luck with those?
Old 05-25-2014, 07:24 AM   #14
Rewards Points: 5,974
I know it's a little late but isn't the stopper not working is usually addressed thru the overflo ?
Old 05-25-2014, 07:57 AM   #15
Could you spray something like pb blaster on it and let it sit? Might soak in enough to break loose...
b75nweav is offline   Reply With Quote
Replacing bathroom sink - questions about tools, drain pipe metazone Plumbing 7 02-09-2014 09:55 AM
Is there a longer bath tub drain flange? Lined cast iron tub. kokobeans Plumbing 0 11-18-2012 09:56 AM
Can bath sink and service sink drain into 1.5" branch drain hammerlane Plumbing 29 11-16-2012 02:37 PM
Replacing Toilet Flange in 1/2 Bath sullijos Plumbing 30 10-11-2011 12:37 PM
Replacing below grade shower drain mgray87 Plumbing 8 07-23-2009 11:44 AM
