Replacing Bath Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-25-2009, 08:59 PM   #1
Rewards Points: 260
Replacing bath tub
I'm in the planning stages of replacing my bath tub. I'm planning to remove all the shower tiles and backer board as well. Will I be able to remove the tub without an access hole to get to the pipes? My main concern is the tub drain.
bluefitness is offline   Reply With Quote
Old 01-26-2009, 12:17 AM   #2
Are you in a slab? If you have a basement, access to the drain should be easy. Are you replacing the tub with another metal tub? If so, I'd recommend looking into getting it professionally refinished. I have used the home depot kits with nightmare results, but friends of mine have paid between 250-300 and had phenominal results from the pros, which I'll be doing down the road.
brokenhammer is offline   Reply With Quote
Old 01-26-2009, 05:40 AM   #3
Man of many hats
wrangler's Avatar
Rewards Points: 354
Depending on the age, the drain should be no problem. Most will come out using a tool called a castle wrench, which slips into the drain and is then turned using a pair of channel locks, screw driver or socket wrench. On some very old tubs I have had to 'tap' them out using and old chisel and hammer, and rarely have to actually use a reciprocating saw due to the drain being corroded to the tub shoe. The over-flow is usually very easy, 1-2 screws then pull the entire assembly out.
HTH,
Brett
Man of many hats
wrangler is offline   Reply With Quote
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 06:45 PM
new bath layout keoki Remodeling 2 06-30-2008 07:40 PM
Laundry Room and half bath overhaul! gone_fishing Project Showcase 10 04-29-2008 07:08 PM
Bath Box drainage all gone bad. HELP shwingirl Plumbing 14 01-03-2008 04:25 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
