Replacing Bath Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-22-2012, 11:56 AM   #1
Replacing bath tub
is there any way to replace your bath tub with out taking the whole wall of tiles down?
kgbishop is offline   Reply With Quote
Old 12-22-2012, 12:37 PM   #2
Have you considered inserting a new tub?
yaacovp is offline   Reply With Quote
Old 12-22-2012, 01:23 PM   #3
Roofmaster
Rewards Points: 2,210
It completely depends on how your tub and tile was installed but usually yes.
If your tile is on green board, I would do this:
Suck out the trap with a shop vac or vacuum pump and transfer bottle and Plug the drain and overflow. The overflow is usually attached with two screws, the drain is screwed in. Plier handles and an adjustable wrench, or channel locks. Take a right angle grinder and cut horizontally at the second tile joint up from the rim of the tub all around. I would go right through the backer board to the studs. Remove those cut out pieces with a wonder bar and a hammer. You might be able to use a multi-tool here too. They work pretty good, and wont throw as much dust. You will have to remove the tile to the right and left outside the tub line also.
Disconnect plumbing. With copper, use a close quarters cutter. Since we don't know what kind of fixture you have we cant comment, we have to assume you are keeping the old fixture. (Im assuming you have the G2 to shut off the supplies to the tub, yes?)
Tubs have a flange that extends up behind the backer-board and tile. Sometimes the tub is fastened into the studs, sometimes just with the nail heads of roofing nails placed adjacent to the studs.
We can walk you through it if you post pictures as you go along. Speculation sucks, and is a waste of time.
Old 12-22-2012, 02:15 PM   #4
Rewards Points: 2,238
You're probably going to have to take out the bottom 2 rows of tile - that
hit the tub.
Cast Iron tub?
Cover it with a heavy drop-cloth/blanket and bust it up with a sledge-hammer.
Or - Saw-Z-All with a carbide blade.
Used both methods - they work.
Wear eye/face protection.
Steel tub?
Be prepared, to go through more than one blade!
If you're going to put in a new tub -
Be prepared to tear out the dry-wall/plaster in front of the tub -
trying not to disturb the existing tile - might have to, though!
Good luck and have fun!
rossfingal
Merry X-Mas!
rossfingal is offline   Reply With Quote
Replacing Toilet Flange in 1/2 Bath sullijos Plumbing 30 10-11-2011 12:37 PM
Replacing a Bath Fan wildflower General DIY Discussions 3 08-07-2011 03:17 PM
Bath P-trap related to tee and stack vent Jim F Plumbing 2 03-29-2010 10:04 PM
Bath fans--how to send 2 to 1 exhaust outlet Bertha HVAC 5 02-22-2010 05:05 PM
Shattered glass down my bath drain! gudgebum Plumbing 3 01-08-2010 12:52 PM
