Old 12-19-2009, 10:59 AM   #1
Replacing basement toilet - what to do about flange
Greetings,
I'm renovating my basement bathroom. I've taken the old toilet and flooring out. I'm not sure what I need to do before putting the new toilet on. The house is about 50 years old. It appears that there was no toilet flange before. The 4" cast iron drain pipe goes right up to the cement floor. There was 1 bolt set in the concrete that was holding the old toilet on (it looks like the other bolt broke off flush with the floor long ago).
My basic plan was to cut the existing bolt off flush with the floor and use the appropriate flange considering the drain pipe is cast iron. I've done some googling and some have mentioned using a twise-and-set flange. Is this right? The inside diameter of the drain pipe is 4". Is that normal/okay?
I also have another stupid question. I'll be putting ceramic tile down. Do I put the tile down right up to the drain, then put the flange on top of the tile and then the toilet on top of that? Do I put the flange down first, then tile up to the flange and then put the toilet down?
I've attached a picture of the existing drain.
mslide is offline   Reply With Quote
Old 12-19-2009, 11:04 AM   #2
the Musigician
DangerMouse's Avatar
i believe a Fernco flange will do the job for you quite well.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 12-19-2009, 02:35 PM   #3
flange then tile
Old 12-20-2009, 07:42 AM   #4
JDC
Plumbing Contractor
JDC's Avatar
Lay the tile then install the flange. You want the bottom of the flange to sit on top of the tile.
There are repair flanges that will slide into your 4" cast iron pipe. These have a neoprene gasket that expands when a few set screws are tightened. After you get the flange installed be sure to anchor it to the floor.
JDC is offline   Reply With Quote
Old 12-20-2009, 08:54 AM   #5
srry your right flooring first my bad
Toilet flange arrangement with new floor bvsmitty Plumbing 2 01-16-2009 06:51 PM
Leaky toilet flange? ScottieBaseball Plumbing 5 01-04-2009 01:57 AM
Problem toilet flange dougm Plumbing 5 11-22-2008 08:32 PM
tile and toilet flange question rbaggett Plumbing 2 11-13-2008 05:43 PM
Replacing a Toilet dandgluna Plumbing 8 07-10-2006 11:09 PM
