Replacing A 3x3x1.5 ABS Tee - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-01-2010, 08:47 PM   #1
Replacing a 3x3x1.5 ABS tee
Hi,
I have an ABS 3x3x1.5 tee that has a crack on the top of the 1.5 side. I was wondering if I could use a filler to fix this or do I have to replace it? If I should replace it can I somehow get the joints apart? I took a couple of pics and attached if they help at all.
Thanks in advance for any help, Rob
Replacing a 3x3x1.5 ABS tee-sany0108.jpg   Replacing a 3x3x1.5 ABS tee-sany0109.jpg
Captain_Blythe is offline   Reply With Quote
Old 11-01-2010, 09:14 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
Thats ugly No filler will work on that!
What I would do is cut the 3x1.5 tee out and replace it. Cut about 6" away from the tee on all 3 sides and use an 1.5" abs coupling and 2, 3" no-hub couplings on the vertical pipe. The no-hub couplings will roll back on themselves so you can slide the tee into position.
Also, while the tee is out of the way, enlarge the topside of the 1.5" hole. I think it settled down and cracked your hub.
Old 11-02-2010, 04:18 PM   #3
Thank you TheEplumber, I thought that was what was involved. Great suggestion about cutting out above the 1.5 tee, I didn't think about the stud settling but that is most likely what happened for sure. Don't know why they cut it so small. I had another leak downstairs at an elbow and after removing it found that the elbow wasn't formed properly when it was made so it had a small leak. Anyway thank you again for your time!
Rob
Replacing old galv irrigation pipe tns1 Plumbing 8 09-11-2010 05:08 PM
Replacing Windows? Kyle Remodeling 13 12-17-2009 08:03 PM
Replacing sliding patio door problems marlinpuppy Building & Construction 2 02-22-2009 09:11 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 08:27 AM
