Replacing 30 Year Old Delta Bathtub Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-06-2010, 12:37 PM   #1
replacing 30 year old delta bathtub faucet
I am trying to replace/repair my bathtub faucet and have ran into a slight problem. the faucet is a single handle 30 year old delta. I have removed the handle and taken out the inner plastic retainer ring from around the stem but cannot remove the outer chrome ring that I assume holds the guts together. I have tried with a pair of channel locks and a pipe wrench using minimal pressure but have only succeeded in rounding off some of the little ridges. Do you have any suggestions how to remove it without damaging the pipes or valve behind the assembly?
markha is offline   Reply With Quote
Old 11-06-2010, 04:48 PM   #2
tap on the outer ring with a hammer or something similar all the way around, the best tools is a strap wrench but typically if you tap it a bit to break up the lime it will come off by hand. I've also given them a shot of wd-40 and let them sit and they come off. Dont twist the whole body or you'll break off the copper tubing on the back of the valve body.
bartnc37 is offline   Reply With Quote
Old 11-06-2010, 08:19 PM   #3
Rewards Points: 352
1. spray with PB blaster, tap lightly for two minutes, let soak overnight.
2. Use a little heat.
3. Cut groove on one side with a Dremel w/cutoff wheel, pry open with screwdriver
plumberinlaw is offline   Reply With Quote
Need help removing Delta bathroom faucet Mr_allthumbs Plumbing 6 06-01-2010 04:50 PM
Replacing 50 year old Wall furnace with new one liz k HVAC 2 11-29-2009 09:22 PM
Bathtub faucet leak... bozonoz Plumbing 4 09-08-2009 08:02 AM
Replacing 47 year old AC unit cable_data_guy HVAC 47 04-15-2009 03:01 PM
Help Repairing a 25 Year Old Delta Shower Faucet shapeshifter Plumbing 5 07-07-2008 08:24 PM
