Replacing 2" Copper - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2011, 02:45 PM   #1
Replacing 2" Copper
Hi All,
In the attached photo, I have a 2" copper vertical mating into cast iron.
I am relocating the sink that was draining into this.
My choices are:
1. Work with the existing copper. Disconnect it all and then resolder it all back together. This will be difficult. I've already tried with the propane torch and it can't get it hot enough to take apart. ( That huge cleanout fitting is sinking all the heat ). I'm sure soldering this big copper pipe is going to be difficult. Any soldering tips for big copper pipe ?
2. Replace the whole thing with PVC. If so, how do I join it to the cast iron bell ?
Thanks.
Mike Mike is offline   Reply With Quote
Old 03-23-2011, 03:11 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 616
Ayuh,... I always have better luck reusing that stuff if I cut it out 1st, then unsweat the pieces...
A bottle of Mapp gas will also help...
If ya go PVC,...
Just leave a short copper stub to get a fernco fitting onto, to join 'em up...
Bondo is online now   Reply With Quote
dishwasher install - replacing copper feh Plumbing 7 03-21-2012 04:12 PM
Replacing old Copper with CPVC epsilon Plumbing 1 06-21-2010 06:39 PM
Upgrading 1.5" Copper to 2" for Standpipe/Drain tigereye Plumbing 11 03-05-2010 06:47 PM
Replacing a section of copper pipe to a Gas Water Heater outlet Question F150dad77 Plumbing 4 10-07-2009 09:32 AM
Connect 2" pvc drain to 2" copper pipe - no subfloor access missfixer General DIY Discussions 3 09-05-2009 06:44 PM
