Replacement Toilet Tank Lid? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-16-2010, 07:19 AM   #1
Rewards Points: 342
Question
Replacement toilet tank lid?
I have a nice older toilet (original to my early 60's ). The lid is chipped and I want to find a replacement. I see several numbers on the backside of the lid but I do not see a manufacturer name on toilet anywhere. Any ideas where I can find a replacement lid.
tripower is offline   Reply With Quote
Old 06-16-2010, 07:35 AM   #2
This item is hard to find with all the info in the world. Most companies do not sell the lid separate from the tank. Tank designs change fast so unless you have a surplus store or a place that rescues parts from houses being torn down, it will be a battle. Look at the display models in stores and you "may" find one that matches the chipped one you have.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 06-16-2010, 09:09 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Call a plumber, they may have one lying around.
Journeyman Plumber
Old 06-16-2010, 11:14 AM   #4
Ahhhh, the old 5 gallon per flush toilets, I got one in my rental unit and even though they waste water, they operate far superior to the 1.6 gallon toilets today. You can't clog the trapway or the downstream line no matter how hard you tried.
So, to answer your question, you might be able to find a replacement lid here:
http://www.toilettanklids.com/
The Engineer is offline   Reply With Quote
Old 12-03-2012, 11:53 AM   #5
swanklid can make you a spiffy toilet tank lid for cheap that matches your bathroom tile -
http://www.swanklids.com/lid.htm
meselffff is offline   Reply With Quote
Toilet Tank Movement dschucky Plumbing 2 05-04-2010 12:41 PM
Bubbles In Toilet Tank JCNimmo Plumbing 2 01-29-2010 08:11 AM
Leaking from toilet tank? tripflex Plumbing 4 09-29-2009 11:29 AM
Setting a Toilet tank against a tiled wall jibanez Plumbing 3 01-17-2009 07:54 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
