Replacement Sink With Cast Iron Model - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-12-2010, 10:18 PM   #1
Replacement sink with cast iron model
Purchased a cast iron kitchen sink today to replace an old acrylic one. The acrylic was installed in a bed of some kind of flexible caulk. I was lucky to have a multi-master to be able to get under the lip and break the bond using a scraper attachment. Love my multi-master. But I digress. Instructions for the new cast iron replacement just say to put the sink in the hole and put a bead of caulk around the edge. Would it be better or not to put a bead around the hole edge before putting the sink in? The counter top is tile and the existing hole is going to be oversize a little so that I will only have about half the overhang had the hole been the size of the template that came with the sink. Will that matter at all? Should I build up the edges of the hole with strips of wood? I was very surprised by how heavy the cast iron sink is. Oh yeah, getting a bead of caulk on the back side is going to be tough. Any recommendations for that problem? Thanks.
Last edited by Mike in Arkansas; 02-12-2010 at 10:20 PM. Reason: tried to edit the title to no avail. oh well you know what i mean.
Mike in Arkansas is offline   Reply With Quote
Old 02-13-2010, 12:22 PM   #2
Rewards Points: 356
I don't think the ovesized hole with be a problem. If it is, the wood will not help anyway. The way I do a cast iron sink, set the sink in place, center it, use painters tape to tape off the counter top around the sink leaving 1/32 to 1/16 gap. Remove the sink, clean the counter top and sink with alcohol. If it is a used sink sand down the part of the sink that will contact the counter and paint it with a metal primer. Put a good bead of silicone caulk on the counter. With a strong helper lower the sink in place and get it lined up as quickly as possible. Scrape and wipe up the excess caulk. Quickly remove the tape and finish off the caulk immediately. Be sure you are well prepared with what ever you will use to trim/clean the caulk before you apply it.
If you try to get away with caulking after you set the sink in the hole you will get rust bleeding onto the counter in the near future.
Rege
RegeSullivan is offline   Reply With Quote
Old 02-13-2010, 05:59 PM   #3
Thanks so much Rege. Would it be okay to use Dap bath caulk instead of silicon under the sink. And, if I apply caulk under the sink I guess I still need to apply a bead around the parameter. Correct? Thanks again.
Old 02-13-2010, 06:14 PM   #4
Rewards Points: 356
Do not apply more caulk. That will cause more problems than it will solve and it will not adhere properly to the partially cured caulk. Make sure you put a bead large enough on the counter so it squeezes out from under the sink a little. You should have a nice neat very, very small line of caulking showing around the sink after you smooth out the bead. The tape helps keep this neat and clean.
Yes - use DAP Premium Kitchen & Bath Adhesive Caulk w/Microban.
Good luck with your project.
Rege
Old 02-13-2010, 07:11 PM   #5
Again, thanks Rege.
Old 02-14-2010, 08:12 AM   #6
Rewards Points: 356
Glad to help... Let us know how it works out.
Cast Iron Sink cellophane Plumbing 4 12-02-2009 01:36 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
Old cast iron sink weighs a ton ex-Khobar Andy Plumbing 7 08-29-2007 03:15 PM
Current trends: Cast Iron or Stainless Steel sink? Fat b Remodeling 4 05-04-2007 07:09 PM
